Designing Raduised Steel Beams
What are some thoughts on designing radiused steel beams? Are there any rules of thumb that experienced engineers use? I have a condition where I have a radiused beam over the entrance to a four story bldg spanning about 20' between columns. It is about 12" eccentric from the cl of columns.
RE: Designing Raduised Steel Beams
For a 20' span, although the amount of curvature appears to be small, you might find that an HSS or TS (depending on the local practice) is more efficient. W Sections are very poor for torsional resistance in general and the size increases substantially. Although the curvature is small, both sections will distort a bit.
Dik
Dik
Dik
