Custom Properties
Custom Properties
Custom Properties
At the request of another user I am writing a macro to help automate the exporting of SW drawings to AutoCAD DWG and DXF. Our office standard is to put the rev level at the end of the filename (ie: 63570018_Rev001.dwg). The current Rev level is stored in the actual model file (sldprt or sldasm) as "Rev". When exporting the SW drawing I need to get the current Rev level of the part or assembly. How can I do this?
Any help is greatly aprreciated.
SolidWorks 2007 SP1
RE: Custom Properties
It is a bit confusing at first.  The custom properties are not actually referred to as custom properties in the API help.  They're referred to as CustomInfo.  There's a pretty good example there in the help and quite a large number of examples posted here.
yeah, I have been searching, found a couple of examples but I still can not get it to work properly. It works but it returns the Rev of the actual slddrw file which is blank. I need it to return the Rev of the part or assembly that is shown on the drawing.
Can you post the macro you are using?
Use [code]post code here[/code]
cheers
DanLan,
Actually in SW2007 you should now look under the CustomPropertyManager; CustomInfo is now obsolete.
To get the Rev level, you must get the modeldoc2 object of the the part or assembly.  One way to do this is to call ModelDoc2.GetDependencies2 (after you have the modeldoc2 for the drawing).  After you have the the model name used in the drawing, you then call SldWorks::GetOpenDocumentByName to get the modeldoc2 of the part or assembly.  Next you get the CustomPropertyManager by calling ModelDoc2.Extension.CustomPropertyManger.  Finally call CustomPropertyManger.Get2 to get the rev value.
SA
SolidAir
Can you possible give some example code for that? I am not that well versed with SolidWorks API yet.
Hi, DanLan:
Go to SolidWorks API Help menu, and type "api custom property".  You will find sample codes for "Get and Set Custom Property Values Example". ".GetCustomPropertyValues" is method you need to get revision info.
According to SolidWorks, also consistent with ASME Y14, only drawing documents have revision.  Models (parts or assemblies) do not have revision although you can force them to have revision.
Also, you may want to take another look at your current file system.  Putting revision info into file names is a very bad practice.  Not every revision of a drawing affect model documents.  To put revision info in file names is just like to put tatoo of a person's age onto his/her face.  You do not want to do that because a person age is changing.
Good Luck!
Alex
rgrayclamps
We put the rev level on the end of the filename when we export to DWG for archiving. this way we can keep every rev level of a part. the reason we give parts and assemblies rev levels so we can keep track of how many changes, all of our parts and assemblies are used on many other assemblies for each product line, some are used across other product lines.
I was looking at the help but I can't seem to get it to work.
Hi, DanLan:
Did you try the following codes from SW API help menu? This is a VB program to set and get custom properties.  You will need to twist it abit in order to run in SW VBA.
Or, maybe you can record one using SW macro command.
Good Luck!
Alex
Get and Set Custom Property Values Example (VB)
This example shows how to get and set custom property values using the SolidWorks Document Manager API.
' Preconditions: E:\2005\linkedProp_ST\LinkedPropTest.SLDPRT exists
' Postconditions: MyMass and MyDimension custom property values are changed
Option Explicit
    Dim swDocMgr                As SwDocumentMgr.SwDMApplication
    Dim swDoc                   As SwDocumentMgr.SwDMDocument
    Dim vExtRefArr              As Variant
    Dim vExtRef                 As Variant
    Dim nretval                 As Long
     Dim tapp                   As SwDMApplication
Sub Main()
'On Error GoTo errorHandler
    Dim classfac As SwDocumentMgr.SwDMClassFactory
    Set classfac = CreateObject("SwDocumentMgr.SwDMClassFactory")
    Set tapp = classfac.GetApplication("")
    Dim d_2005 As SwDMDocument3
    Dim s1 As String
    Dim e As Long
    Dim proptype As Long
    Dim path As String
    path = "E:\2005\linkedProp_ST\"
    Set d_2005 = tapp.GetDocument("E:\2005\linkedProp_ST\LinkedPropTest.SLDPRT", swDmDocumentPart, True, e)
Dim v As Variant
v = d_2005.GetCustomPropertyNames
    Debug.Print 'param string: ' & d_2005.GetCustomProperty('MyMass', proptype)
    Debug.Print 'value: ' & d_2005.GetCustomPropertyValues('MyMass', proptype, s1)
    ''Note, you can also get the param string from
    ''SwDMDocument3::GetCustomPropertyValues or
    ''SwDMConfiguration4::GetCustomPropertyValues linkedTo parameter (s1)
    Debug.Print 'param string: ' & s1
    Debug.print ' '
    Debug.Print 'param string: ' & d_2005.GetCustomProperty('DocLevelNL', proptype)
    Debug.Print 'value: ' & d_2005.GetCustomPropertyValues('DocLevelNL', proptype, s1)
    Dim c As SwDMConfiguration4
    Set c = d_2005.ConfigurationManager.GetConfigurationByName("config_h1")
    Dim v2 As Variant
    v2 = c.GetCustomPropertyNames
    Debug.Print "param string: " & c.GetCustomProperty("MyDimension", proptype)
    Debug.Print "value: " & c.GetCustomPropertyValues("MyDimension", proptype, s1)
    Debug.Print "param string: " & c.GetCustomProperty("ConfigLevelNL", proptype)
    Debug.Print "value: " & c.GetCustomPropertyValues("CONFIGLEVELNL", proptype, s1)
    Set c = d_2005.ConfigurationManager.GetConfigurationByName("config_h3")
d_2005.SetCustomProperty "MyMass", "new non-linked value"
Debug.Print "param string: " & d_2005.GetCustomProperty("MyMass", proptype)
Debug.Print "value: " & d_2005.GetCustomPropertyValues("MyMass", proptype, s1)
c.SetCustomProperty "MyDimension", "new non-linked value, CS"
    d_2005.CloseDoc
    Set d_2005 = Nothing
    Set tapp = Nothing
    Set classfac = Nothing
End Sub
DanLan,
Could you post your code so that I could post an example in the code style you are using?
SA
the code is a bit messy right now but here it is...
CODE
Private Sub CommandExport_Click()
  'added by Dan Landrum      version 1.10                       === begin ===
  Dim iSelectCount As Integer
  'added by Dan Landrum      version 1.10                         === end ===
  'added by Dan Landrum      version 1.11                       === begin ===
  Dim strRev As String
Dim vDepend             As Variant
Dim swModel1            As SldWorks.ModelDoc2
Dim CPM                 As CustomPropertyManager
Dim vPropNames          As Variant
Dim nNbrProps           As Long
Dim custPropType        As Long
Dim valOut              As String
Dim resolvedValOut      As String
Dim swConfigMgr         As SldWorks.ConfigurationManager
Dim swConfig            As SldWorks.Configuration
  'added by Dan Landrum      version 1.11                         === end ===
  CheckBoxFilter.Enabled = False
  TextBoxFilter.Enabled = False
  TextBoxFilter.BackColor = vbButtonFace
  CommandSelect.Enabled = False
  CommandClear.Enabled = False
  CommandSelectAll.Enabled = False
  CommandClearAll.Enabled = False
  LabelType.Enabled = False
  ListBoxUserSelect.Locked = True
  ComboFileType.Enabled = False
  ComboFileType.BackColor = vbButtonFace
  CommandExport.Enabled = False
  CommandClose.Enabled = False
  TimeStart = Now
  CT = 0
  For x = 0 To ListBoxUserSelect.ListCount - 1                 ' each item
    If ListBoxUserSelect.Selected(x) = True Then               ' item select
      CT = CT + 1
    End If
  Next                                                         ' Get next cfg
  LabelStatus.Caption = ""                                     ' Clear status
  DocName = ModelDoc2.GetTitle                                 ' Doc title
  'if there is only one sheet then we don't want the sheet name
  'tagged onto the end of the filename. So we check the quantity of items in
  'in the list and that the user selected only one item for export.
  'If only one item then we remove the sheet name from the docname.
  blnNameset = False
  If DocMode = 1 Then
    iSelectCount = 0
    For i = 0 To ListBoxUserSelect.ListCount - 1
      If ListBoxUserSelect.Selected(i) = True Then
        iSelectCount = iSelectCount + 1
      End If
    Next
    i = 0
    z = 0
    Set swConfigMgr = ModelDoc2.ConfigurationManager
    Set swConfig = swConfigMgr.ActiveConfiguration
Set CPM = swConfig.CustomPropertyManager
nNbrProps = CPM.Count
vPropNames = CPM.GetNames
'Set CPM = swModel1.Extension.CustomPropertyManager("")
For j = 0 To nNbrProps - 1
  CPM.Get2 vPropNames(j), valOut, resolvedValOut
  custPropType = CPM.GetType2(vPropNames(j))
  Debug.Print "    Name, type, and resolved value of custom property:  " & vPropNames(j) & " - "; custPropType & " - " & resolvedValOut
Next j
'strRev = CPM.Get2("Rev", "strRev", "strRevResolved")
MsgBox ("Revision: " & strRev)
    If iSelectCount = 1 Then
      For i = 1 To Len(DocName)
        If Mid$(DocName, i, 1) = "-" Then z = i
      Next i
      DocName = Left$(DocName, (z - 2))
      blnNameset = True
    End If
  End If
  DocPathname = ModelDoc2.GetPathName                          ' Doc path
  For i = 1 To Len(DocPathname)
    If Mid$(DocPathname, i, 1) = "\" Then z = i                ' last slash
  Next i
  DocPath = Left$(DocPathname, z)                              ' remove doc nam
  Count = 0
      If DocMode = 0 Then               ' -- SolidWorks Models --
        ThisConfigName = ListBoxUserSelect.List(x, 0)
        ExportName = DocName & "_" & ThisConfigName & _
                     ComboFileType.List(ComboFileType.ListIndex, 1) ' Export name
        LabelStatus.Caption = " (" & Count + 1 & "/" & CT & ")" & _
                              " Exporting: " & ExportName      ' Show name
        FormDocExport.Repaint                               ' Repaint form
        ModelDoc2.ShowConfiguration2 ThisConfigName            ' Show config
        ModelDoc2.GraphicsRedraw2                              ' Redraw screen
        ModelDoc2.SaveAs4 DocPath & ExportName, swSaveAsCurrentVersion, _
                   swSaveAsOptions_Silent, Errors, Warnings    ' Create file
        Count = Count + 1
        CheckBoxFilter.Enabled = True
        EXType = "configurations"
      Else                              ' -- SolidWorks Drawings --
        ThisSheetName = ListBoxUserSelect.List(x, 0)
        ModelDoc2.ActivateSheet ThisSheetName                  ' Show sheet
        'if we already set the name above then don't do it here
        If blnNameset = False Then
        End If
        'REM out next line, part of original code.
        'DocName = ModelDoc2.GetTitle
        ExportName = DocName & _
        LabelStatus.Caption = " Exporting: " & ExportName      ' Show name
        Count = Count + 1
        EXType = "sheets"
      End If
    End If
  Next                                                         ' Get next cfg
  TimeEnd = Now
  LabelStatus.Caption = " Done: " & Count & " " & EXType & " exported in " & _
           Format(DateDiff("s", TimeStart, TimeEnd) / 60, "###.00") & " minutes."
  CheckBoxFilter_Click
  CommandSelectAll.Enabled = True
  CommandClearAll.Enabled = True
  ListBoxUserSelect.Locked = False
  LabelType.Enabled = True
  ComboFileType.Enabled = True
  ComboFileType.BackColor = vbWindowBackground
  CommandExport.Enabled = True
  CommandClose.Enabled = True
End Sub
rgrayclamps,
The example you posted is for documentmanager.  Generally you do not use this on open documents (at least that is how I would use it).
SA
I have tried several different things, that just happened to be the last thing I was trying.
DanLan,
Try this code.
CODE
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim swDwgModelDoc As SldWorks.ModelDoc2
Dim swModelDoc As SldWorks.ModelDoc2
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim vDwgDependent As Variant
Dim strRevResolved As String
Sub main()
    'get solidworks
    Set swApp = Application.SldWorks
    'get drawing modeldoc
    Set swDwgModelDoc = swApp.ActiveDoc
    'get path/name of model or assembly doc used to make drawing
    vDwgDependent = swDwgModelDoc.GetDependencies2(False, False, False)
    'assume only one model or assembly doc for drawing
    'get dependent modeldoc
    Set swModelDoc = swApp.GetOpenDocumentByName(vDwgDependent(1))
    'get custom property manager for modeldoc
    Set swCustPropMgr = swModelDoc.Extension.CustomPropertyManager("")
    'get revison value
    swCustPropMgr.Get2 "Rev", strRev, strRevResolved
    'display revision value
    MsgBox "Model Revision is " & strRev & "     ", vbOKOnly, "Example Program"
End Sub
SA
SA,
To take your comment about document manager a bit further, can you use DocumentManager on an open document?  I haven't messed with it much, but I'm not sure if you can get the current, open version of a file into DocumentManager.  (I used that fact in a macro to compare the update stamp on disk with the update stamp in memory and determine how many changes were made since the last save.)  If this is the case, then using DocumentManager would generally leave you wide open to missing changes made in the current SW session.
Handleman,
I do not understand.  In your post you stated:
Does that mean you were able to have the model open and get the SwDMDocument object?  From a test I just conducted, if I tried to access the file on the disk with the file open, the swDMDocument object came back equal to Nothing and the result parameter set to swDmDocumentOpenErrorFail which according to SW API help means
Quote:
//File failed to open; reasons could be related to permissions or the file is in use by some other application or the file does not exist
However, if I saved the file to a different disk and left it open and ran the code again so it tried to access the file (with the same filename) on the first disk, then an object was returned and the result parameter came back equal to swDmDocumentOpenErrorNone.
So the to answer your question is No when you try to access the same file on a disk that is also open in SolidWorks.  And Yes if you try to access a file on a disk with the same name as a file open in SolidWorks that was opened from a different disk.  In all cases disk includes a path which means the the files could reside on the same disk drive but in different folders.
SA
SolidAir
Thanks a million... works like a charm...
ok, I have another question about this...
I noticed that the Rev level will not be retrieved if that property is stored as configuration specific property. There is only one configuration shown per sheet. Is there a way to get the Rev level then?
that's not possible...
each configuration is the same basic part but has different hole patterns punched in it.
each individual configuration may get updated which requires the rev to roll forward for that configuration.
DanLan,
You should be able to do this.  The SldWorks.ModelDoc2.CustomInfo2 method can take a string specifying which configuration to retrieve the property from.  You can use SldWorks.view.ReferencedDocument and SldWorks.view.ReferencedConfiguration to get the model and configuration named used in a view.  Hopefully that will be enough to point you in the right direction.
Eric
Thanx, got it...
CODE
Option Explicit
Dim swView As SldWorks.View
Dim swDraw As SldWorks.DrawingDoc
Dim strConfig As String
Sub main()
    'get solidworks
    Set swDraw = swDwgModelDoc
    Set swView = swDraw.GetFirstView
    Do While Not swView Is Nothing
        Debug.Print "  View = " + swView.Name
        Debug.Print "    Model  = " + swView.GetReferencedModelName
        Debug.Print "    Config = " + swView.ReferencedConfiguration
        strConfig = swView.ReferencedConfiguration
        Set swView = swView.GetNextView
    Loop
    Set swCustPropMgr = swModelDoc.Extension.CustomPropertyManager(strConfig)
    'get revison value
    MsgBox "Model Revision is " & strRev & "     " & "Config: " & strConfig, vbOKOnly, "Example Program"
End Sub
