ASTM A749/A749MM
ASTM A749/A749MM
ASTM A749/A749MM
I have a callout on a print for "material must conform to ASTM A749/A749m".  I am quoting a rivet from an assembly drawing that specifies the same material for the plate steel and the rivet.  I am unable to find any info on this astm spec.
