Beam calculation software
need software for calculation of stresses and reactions on some beam assembly (not the easy beam on two supports..). preferibly distributed for free or shareware.
Does anyone have suggestions?
thanks to all
thanks to all
RE: Beam calculation software
Nigel Waterhouse
n_a_waterhouse@hotmail.com
A licensed aircraft mechanic and graduate engineer. Attended university in England and graduated in 1996. Currenty,living in British Columbia,Canada, working as a design engineer responsible for aircraft mods and STC's.
Nigel Waterhouse
hope you have more suggestions.
thanks anyway
Nigel Waterhouse
thx bye
It is called Multi-Bender and you may download a copy from www.cedarhouse.co.uk
You need a frame analysis package and the two that spring to mind are Cadre and GRAPE. Both can be downloaded from the internet an both will take you some time to get used to Also GRAPE will not give you the BM diagram. I have don't know about CADRE. I have only seen this facility on expensive programs.
You can draw any model you like 3d or otherwise in Autocad and DXF it into CAdre, this makes construction the model quick and easy.
Nigel Waterhouse
You can download a demo of the program for free, and the full version is $40US.
Chris Rosencutter
chris@mecaconsulting.com
Only quite simple beams are treated for the time being, but will grow...
prex
motori@xcalcs.com
Xcalcs
Structural calculation software for direct usage on-line from your browser's window
You can find it at www.orandsystems.com
http://www.bridgesite.com/softwarelinks.htm
Hope this is helpful,
Jelto
I also use CadreLite (http://www.cadreanalytic.com/) for US$92 which is better for frames or 3D structures, but no so easy to use.
Juerg Hoelzle
juerg.hoelzle@ruag.com
http://www.ruaglandsystems.com
http://www.ruag.com
i think ANSYS will solve ur problem.
if u need any help pls contact on following id
omakr_mi2@yahoo.co.in
