Any experience of CH plug valves
Has anyoine any experience of the performance of CH plug valves manufactured in S.Africa?
technical and commercial experiences woul;d be appreciated.
RE: Any experience of CH plug valves
a) Generalize: What is the best possible solution for following application..... etc. (type of valves)
or
b) We have following problems with..... (specify).
If you just want references on the valves for your application : ask the supplier to give for instance five references, and ask the largest competitor/supplier for the same.
References without specifying the application and requirements (for instance required expected life-time and and what service/sparepart and overhaul-cycle with expected total lifetime cost) would not give you very valuable information.
