Dimensioning hole patterns
When dimensioning a hole pattern i.e. 6 holes, 3 horizontally and 2 vertically in line with each other respectivly, is it appropriate to have 3x or 2x on the location dimensions for the holes when not using center lines?
RE: Dimensioning hole patterns
O O O
1 set of X-Y dims to locate a corner hole, then a 3X dim for the vertical distance, and a 4X dim for the horizontal spacing. Why aren't you using centerlines?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
On dim between the top 3 and bottom 3 holes would have 3x and the dim locating the 3 sets of verticle holes would have 2x on each. Sometimes too many centerlines can be confussing.
