Assm. Part Transparency using DT?
I've searched around for this, but I'm not sure if it's possible. I know you can control a part's color using a design table, but if I have a DT in an assembly, can I alter a part's transparency?
For instance, in a four-part assembly, one configuration would highlight part 1 while forcing transparency on parts 2-4; config 2 would highlight part 2 while 1, 3, and 4 were transparent, etc.
Thanks.
RE: Assm. Part Transparency using DT?
Set up two configs the way you want them, then auto-create a design table to see what the parameter is that you need to cange for the rest of the configs.
Last time I seen this questioned asked it was not possible. As far as I know its still the same way, however I could be wrong.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
FAQ731-376
Thanks for the replies. Handleman, that's what I had tried prior to posting, with no luck. After seeing Scott's post it looks like I may end up doing it manually in each config. Time for an enhancement request!
Investigate Display States in a DT. You may be able to use/manipulate those in a DT.
cheers
