M50 VIM-VAR Alternative Material
Due to the material M50 VIM-VAR (high performance bearing steel) becoming increasingly hard to obtain, I am searching for a similar material to use. This steel is common for jet engine bearings. Does anyone know of a readily available material that is replacing the use of M50 VIM-VAR???
RE: M50 VIM-VAR Alternative Material
ht
http://ww
