Monel 400 stud
Monel 400 stud
I have a customer who requires studs to meet SA-193 (Grade B7) , we currently use Monel 400. From what I've been able to find out this material is not SA-193, but does it exceed SA-193? And if so is it generally an acceptable practice to substitute a higher grade material for SA-193?
RE: Monel 400 stud
See ASTM A193/A193M, 'Standard Specification for Alloy-Steel and Stainless Steel Bolting Materials for High Temperature or High Pressure Service and Other Special Purpose Applications.'
h
Monel 400 might have better corrosion resistance in some applications at lower temperatures, but A193 is a specification for high temperature material. The Monel 400 may anneal, weaken & fail in use.
RE: Monel 400 stud
Give them the SB spec that your studs meet and the properties and let them decide.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
RE: Monel 400 stud
Monel bolting is listed under ASME SB 164, and is limited to service temperature at or below 900 deg F depending on condition and use in service. So, read up.
