Need 3d model of Beck Drive (an elec driven damper actuator)
Need a 3d model of a Electric damper drive, made by Harold Beck & Sons, model 400.  I called them and they have Solidworks models for newer assys but not this one.
Thank you,
Dee
RE: Need 3d model of Beck Drive (an elec driven damper actuator)
Are the new ones similar to the model 400?
Would it be a relatively simple task to convert new to old?
cheers
I don't know.  I will check if nothing turns up, thank you
ProjectEng99,
  May I ask what you are using this for?  I assume you mean an 11-400 model?
Pete
Using it to drive a 10ft x 10ft metal louver damper.
Yes model 11-408-1800-36-2LS
Thank you
Dee
There are no models that exist for this drive, but you could model the geometry based on the information given in the manual.  You don't need a perfect representation do you?  I would imagine a rough shape would suit your purposes.  There are outline dimension drawings in the manual that would provide all the info you need.
Pete
No I don't need a perfect model.  Yes I have the outline dwgs.  Just trying to save time.  We're busy on other stuff but will build it ourself.
Thank you,
Dee
I understand Dee.  We do have models available for Group 29 and Group 42 drives.  These are the newer models that were referenced in your first post.
Pete
The 29 and 42 aren't very close but thank you for your help.
Dee
