Assembly Links
Assembly Links
Hi
I have one assembly with 4 parts inside; in the second part I have more sewed surfaces from part 1 created with wave geom. link. which are used to create a solid.
But in the meanwhile those surfaces are completely modified and now I must replace somehow part 1 inside the assembly with the new part, but to keep the linked surfaces (or recreate) because I want to update the solid.
Can I replace that part in assembly but without losing the links?
Thanks to all.
Regards.
Thanks to all.
Regards.
RE: Assembly Links
-Dave
Everything should be designed as simple as possible, but not simpler.
RE: Assembly Links
Can you be more precise please?
I should use “substitute component “command, with maintain mating or some other command ………
Can you tell me all the steps that I should follow?
RE: Assembly Links
-Dave
RE: Assembly Links
good luck..
Tobias.
