Elec. Resistivity of Blast Furnace Slag
I am trying to find 'typical' values for resistivity of crushed air-cooled iron blast furnace slag, which will be used as structural fill. The subject came up as part of a grounding design. The gradation spec on the material is pretty broad, allowing sizes up to 10 inches with only about 10 percent passing the #40 sieve. The material is expected to be relatively well drained.
A Google search returns very little except vague statements that slag resistivity is 'very low.'
Any information would be appreciated. Thanks.
