GPSA DB Example 7-1...Where Did 379 Come From?
The 12th edition of the GPSA Data Books contains a example (7-1, page 7-12) for separator sizing and and the mass flow equation has the value 379 in the denominator. The only thing I can figure is that value represents the product of the gas standard specific volume (17.45 ft3/lb) and molecular weight (21.72). Yes/No????
The reason I ask is because I'm familiarizing myself with how my peers size the separators we manufacture. The accepted spreadsheet uses the same mass flow rate equation with 379 as a constant; a practice I believe is in error.
Before I [the new guy] bring up this issue I'd sure appreciate a sanity check from someone more in the know. I'm a little hesitant because doing as I did, the GPSA mass flow equation would cancel the mol. wt. out of the numerator and leave just the specific volume as a denominator variable. To me, that would be a better way to show the equation which means I'm probably wrong.
RE: GPSA DB Example 7-1...Where Did 379 Come From?
After my original post I found a similar equation (w/379.5) in API 11P but it at least identifed its units (scf/mol).
Thanks for the clarification; I get turned around easily by ideal gas law principles. I'm going to go crawl back under my Mechanical rock.
I haven't checked my latest, electronic version of the GPSA Engineering Data Book, but the old, reliable, Hard Copy, multi-ring binder version has always had the "Constants for use in Calculations" listed in the old Section 16, Physical Properties. There, you will see the first listed constant: 1 mole = 379.49 cu ft @ 14.696 psia & 60 oF (for an ideal gas). In the old daze, we used 380 and got away with it.
It probably became so obvious (to everyone but me) that GPSA dropped it.
My ignorance aside, there's a lot to be said about showing units all the way through one's calculations. I value the GPSA DBs but that is a short coming I've noticed.
