Active Document Filename and Path access in VB
I am working with SolidWorks 2006 and have a macro/vb app that I am trying to get the filename and path for the active document.  Is this possible, and if so, how?  Please, any help will be much appreciated.
RE: Active Document Filename and Path access in VB
Use "SldWorks.ActiveDoc" to get the active document.
Use "ModelDoc.GetPathName" to get the document's path.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
I knew it had to be simple, but dang if I could find it.
