airflow velocity
airflow velocity
airflow velocity
Designing a heating core into a 1.5 inch tube to raise an ambient temp. of 40 degrees to 60 degrees. Have a flow velocity of 98 CFM produced by a squirrel-cage fan, but have no way of finding the PRESSURE of the air-flow. I suspect it's less than 15 psi... Any assistance would be most helpfull...
RE: airflow velocity
Are you wanting to measure the static pressure in the pipe or the  dynamic pressure of the free air flow from the fan?
Nigel Waterhouse
n_a_waterhouse@hotmail.com
A licensed aircraft mechanic and graduate engineer. Attended university in England and graduated in 1996. Currenty,living in British Columbia,Canada, working as a design engineer responsible for aircraft mods and STC's.
