NDT's Mandatory/Required by ASME Code
I need help to understand what is mandatory by the ASME Code about Non Destructive Testing (NDT) during the fabrication of pressure vessels. When a technical specification for a Pressure Vessel is prepared, How to know exactly what NDT’s have to be included in that specification as mandatory?, What part of the ASME Code describe the NDT’s requirement?
Thanks in advance.
Thanks in advance.
RE: NDT's Mandatory/Required by ASME Code
Yes I have.
To expand on metengr's reply,in addition to UW, you are also going to need to review the applicable sections in
Subsection C and the Appendices applicable to the NDE methods in question.
RLS
When no supplementary NDT is necessary only put " NDT according to ASME VIII Div. 1".
Please see ASME V when you design a pressure vessel
rhg
It is impossible to design and stamp a pressure vessel to the ASME code with NO NDT performed: Visual examination, hydrostatic test are NDT and mandatory
rhg
Sorry to nitpick, but I don't consider hydrotest to be a NDT. Hydrotest is a proof test. I view NDT as being limited to those methods referenced in Section V. Visual is, hydrotest is not.
Jr97
I think it's reasonable to consider the hydro as NDE. The test does not render the part unuseable. In fact the hydro pressure specified is limited to that which would typically cause damage. The ASME Code defines a proof test and it is completely different than a hydro.
Joe Tank
JR97: please see ASME V article 30 standard terminology for NDE SE-1316
"NDT: the development and application of technical methods to examine materials or components in way that do not impair future usefulness and seviceability in order to detec, locate, measure, and evaluate flaws; to assest integrity, properties, and composition, and to measure geometrical characters"
regards
rhg
I am afraid I am sticking to my position. (Please humor me one more time.) Section V, Article 1 paragraph T-110 lists the NDE methods recognized by the Code ... Hydrotest is not listed. Also, Referring to Section III, NDE requirements are detailed in Article NB-5000 (Examination), hydrotest requirements are detaile in Article NB-6000 (Testing).
I believe classifying hydrotest as an NDE method confuses the issue. Would you extend the Section NB-5500 (Qualification and Certification of Nondestructive Examination Personnel) to hydrotest personnel?
I concede I misused the term 'proof test' in my earlier post. The Code classifies hydrotesting as a 'pressure test' (ref. NB-6111).
Pressurizing the inside of a vessel can be a form of leak test, which is an NDE method - "pressure change test" per Section V, Article 10, Appendix VI. However, the test time cannot be a blanket 10 minutes as required by the Pressure test of NB-6000. To be effective as a leak test the test pressure, volume, and minimum detectable pressure drop (after consideration of temperature variations) must be correlated to the required leak rate to determine the test time.
Thanks for humoring my nitpick and I am sorry for allowing this thread to drift off topic.
JR97
You're right. It's a test, not an examination.
Joe Tank
It is my belief that hydro is part of an NDE or NDT.
that's how is listed in my dwgs
and ASME team leaders are happy with that
genb
Cheers,
gr2vessels
typical stress concentration factors for holes , branches, transitions is on the order of magnitude of 1.8 to 3.0, and for pre-existing cracks ( from welding process) is approximately 5. If the material is not ductile ( either because of too low a hydrotest temp, or incorrect fabrication , including lack of PWHT , lack of N+T ( when required), wrong weld electrode, "poisoning" of alloys ) then the stress at the tip of the pre-existing carck can grow to catastrophic failure during hydro test. So, if it down't fail, there is "proof" that the desing and fab and test was correctly accomplished.
