Animation
Animation
Animation
Is there a way to animate in Solidworks? I have a bellows design that I'd like to show what happens during collapse and expand. If a third party add-on is the answer that's okay be me.
Thanks - Dave
RE: Animation
Solidworks Animator is an add-in that comes standard with the Professional and Premium Solidworks packages.  Go to Tools/Add-ins and check Solidworks Animator.  If it isn't in the list talk to your VAR about an upgrade.
Dan
www.eltronresearch.com
RE: Animation
Animator won't flex a part during animation (such as a flexible bellows), but will manage the movement of parts in an  assembly relative to one another.  You set constraints of the parts in your assembly using mates (as usual) and then use Animator to move parts relative to time.
It has its limits--still need to develop Animator in a few more areas to make more robust, in my opinion, but when coupled with PhotoWorks, you can gain photo-real rendered animations:
http://www.industrialdesignhaus.com/internet/G2-38-Tommy-Gate.wmv
One of my chief complaints is that you must choose to use either PhotoWorks (photo-real) or SolidWorks materials for rendering--only SolidWorks materials will fade in or fade out in appearance in an animation.
Jeff Mowry
Reason trumps all.  And awe transcends reason.
RE: Animation
If you know FEA, try COSMOS-Express or COSMOS.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
RE: Animation
If you don't have Animator, look into a little piece of software called imagetoavi (google it, I think it is freeware). You provide a series of jpeg files and the software assembles them in an avi video. You may need to play around with it a little to get it right. I used it and I know it works.
