Large Assembly's
Large Assembly's
hello,
We have an Assembly with manny parts. (500 +)
We are using sub - Assembly's for the parts but we were wondering if there was a quick way to put for example al our DIN, ISO elements in one folder in the assembly.
RE: Large Assembly's
If it is inside the assembly- not if you have links to other parts or constraints on these items. With no links, create a blank component, Ctrl F, Workbench = Assembly design, type = Part, search for a common file name ISO*
Right click over name - CUT, Right click over new component - PASTE.
our design tree is way to long, if you are looking for some parts it will take u a long time.
Assembly ONE
--> Sub assembly 1
-->111
-->000
--> Sub assembly 2
-->111
-->000
--> part 1
--> part 2
--> part 500
--> ISO bolt, screw 1
--> ISO bolt, screw 2
--> ISO bolt, screw 600
we want to arrange everything in the assembly
to make it more clearly, more synoptic.
does there exists a manner to arrange everything without
sub assembly's, component,...
You can use functions like Parent/children and Center Graph to assist you in navigating the tree.
Derek
