Motor
Motor
I have a d.c compound motor,110v,25A draws a steady high current of 100A,when connected to the supply.What are the possible causes and remedy.
Gobir
RE: Motor
Loss of excitation? I presume there's a mechanical load. Otherwise a coumpound motor is known to self-destroy at high speed.
Gunnar Englund
www.gke.org
RE: Motor
No shunt field is a great way of doing this. A more remote possibility is a reversed shunt field being almost perfectly cancelled by the series field carrying stall current leaving virtually no net field.
Remedy is check the shunt field is a) carrying current b) of the correct polarity.
  Sometimes I only open my mouth to swap feet...
RE: Motor
The series field ampere turns must add to the shunt field ampere turns. If the polarities are different one field tries to cancel the other, then the total magnetic flux is reduced and the armature counter electromotive force is low.
Since the armature and series field resistances are low the armature current increases. See diagram below.
 Check that you have current into this shunt field. If you check current is OK, then reverse F1 and F2 connections to make your field cummulative.
RE: Motor
Is it drawing 100 amps loaded or unloaded?
What is the load?
respectfully
