Correct terms for Straightener, Edge Cutter etc?
In a machine for straightening rolled steel plate, there is an Unwind Stand, a "Pre-Straightener", a section that pulls the sheet, the Straightener (with two drives), an edge cutter and a take-up stand.
The description is in German and I try to translate it into English. I am electrical by nature and Swedish is my native tongue so I do not automatically have the correct words for the different parts of the machine. Some help in verifying that these are the correct terms (or, if not, what are the correct terms?) would be very welcome.
There are also details like the Spindle that carries the coil in the Unwind Stand. Do you just say Spindle? And the segments in the Spindle, that expand to keep the coil, do they have a special name - or just "Segments?".
Also, the machine that cuts the band into square/rectangular sheets - what would it be called in English? Cutter? Or Square Cutter? Or something else?
And, finally, the steel sheet or band that is being straightened, what is the correct name for it?
Gunnar Englund
www.gke.org
RE: Correct terms for Straightener, Edge Cutter etc?
Hope this helps.
BK
Gunnar Englund
www.gke.org
Thomas J. Walz
Carbide Processors, Inc.
www.carbideprocessors.com
The spooling machine that pays out the sheet is usually called a "de-reeler". It is motorized and turns on demand in response to a "dancer", which is a sort of lever rod that lays on the slack portion of sheet and operates a switch that turns on the de-reeler motor when there is too little slack in the sheet. The metal comes on a "coil", which, as Bklauba noted, is placed on a "mandrel". If the material is thin and narrow it sometimes comes on a "spool". I would call the inner expanding parts of the mandrel "jaws", but that might not be the term that the de-reeler people use.
The rollers that pull the sheet through the machine are "feed rollers".
In sheet metal, the straightening portion is also sometimes called a "leveler" and the whole operation is called a "level and cut line".
Don
Kansas City
I don't know. I was sent the German document and I haven't seen the machine. No drawings there.
Don,
No, it is a huge machine in a rolling mill. Heavy gague steel strip. So there's no dancer on it. The tension is controlled by computing coil diameter from de-reeler rotational speed and line linear speed and applying a suitable torque to the motor. That "Leveler" word seems to fit. I found a reference to a "Leverer" in the German original. I think that your version is more correct. Thanks.
Gunnar Englund
www.gke.org
