Q-Checker
Q-Checker
Anyone got experiance in using Q-Checker?
RE: Q-Checker
RE: Q-Checker
I have experiance in using same in other programs
but never done this one should start soon just intrested
if this one is any good.
RE: Q-Checker
Do you have administrative rights?
Usually, your client should give you a profile, according with his needs...
Fernando
RE: Q-Checker
Do not have admin rights but I can start program
can spec what I want but can not establish link
beetwin part or assy and get report.
I am starting Q-check while in catia on first place
can not find icon any other way.
RE: Q-Checker
Take a look here:
http:
Fernando
RE: Q-Checker
It is working, got results but not there with how to read it all. Do you use it in real production and how?
Aida
RE: Q-Checker
Yes, I'm using Q-Checker when I'm finishing something (CATPart, CATProduct, Model or Drawings in v4 or v5).
You can run it also from VPM directly.
Basically, its corecting some small errors done during your work (things which might be corect for other companies but not for those which gives you a specific profile).
The software allow you to corect automatically some mistakes but for others you have to repair it manually.
You can see also the area where the problem is existing and the element which create the problem.
The best way to understand the software is to read those manuals for your version.I know there are a lot of pages but...
Fernando
