VB Form on top
3
VB Form on top
VB Form on top
How do I make a VisualBasic form stay on top of SW window (be visible all the time with SW window maximized)?
Andrew
RE: VB Form on top
I have this as a separate function for use by several forms.
Const SWP_NOSIZE = &H1
Const SWP_NOMOVE = &H2
Const HWND_TOPMOST = -1
Const HWND_NOTOPMOST = -2
Public Declare Function SetWindowPos Lib "user32" (ByVal hwnd As Long, ByVal hWndInsertAfter As Long, ByVal x As Long, ByVal y As Long, ByVal cx As Long, ByVal cy As Long, ByVal wFlags As Long) As Long
Public Sub ForceWindowOnTop(hwnd As Long, bTrueFalse As Boolean)
    Dim i
    If bTrueFalse = True Then
        i = SetWindowPos(hwnd, HWND_TOPMOST, 0, 0, 0, 0, SWP_NOSIZE Or SWP_NOMOVE)
    Else
        i = SetWindowPos(hwnd, HWND_NOTOPMOST, 0, 0, 0, 0, SWP_NOSIZE Or SWP_NOMOVE)
    End If
End Sub
'Then, to call it from a Form:
Private Sub Form_Load()
    Call ForceWindowOnTop(Me.hwnd, True)
End Sub
'To turn it off, just use False
Hope this helps...
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
RE: VB Form on top
dsi,
I tried to use your function but I get the following error:
Compile error
Constants,  fixed-length strings, arrays, user-defined types and Declare statements not allowed as Public members of object modules.
Andrew
RE: VB Form on top
How can I remove the leader added by SW when I insert a block?
A
RE: VB Form on top
You need to put the declaration of contants in a module. You can not declare constants in the source of a form.
Put this in a module:
    Dim i
    Else
    End If
End Sub
Use the function call-outs in the form:
End Sub
Call ForceWindowOnTop(Me.hwnd, False)
The leader question should be a separate thread.
RE: VB Form on top
dsi,
Works great, thank you.
Andrew
