Reference a model dimension in a text note?
Hello Everyone.
I use both SolidWorks 2006 and PRO/E wildfire 2.0 for CAD.
Main Question:
How do I reference a model dimension while making a drawing in Solidworks?
In PRO/E, I would simply write something like "...drill &d45 dia. holes as shown..." Where "&" symbol is used along with the model dimension name d**, to display the actual value of the dimension in the text. Can you do anything like this in SolidWorks? If so, how? I feel like there has to be a way!
Thanks!
RE: Reference a model dimension in a text note?
Sure.  While typing the text of the note, just click on a dimension and the text will be inserted.
Thank you for the tip! The trick did work for notes. Although, it doesn't work for following case:
Say I am creating a c'bored tapped thru hole...I will use the whole wizard to call out the tapped thru hole. Then, I would like to add c'bore information (depth and diameter) to the hole wizard's callout. I don't want to have a seperate callout for each feature. Therefore, I am trying to figure out the nomenclature needed to reference those dimensions.
curiousmechanical,
Goto Insert, Annotations, Hole Callout.  Select the counterbored hole and see if the result is what you want.
SA
curiousmechanical ... submit an ER if you need the counterbored tapped hole callout often.
cheers
You can't link text in one dimension to the value of another dimension.  If I'm remembering right, a SolidWorks hole callout is actually a form of dimension rather than a note.  As such, I don't think you can link text in a true hole callout to another dimension.
If you want your note to be linked to a dimension but not have that actual dimension show you can RMB on the dimension and choose "Hide" after linking.
There is an option somewhere under Tools->Options that mentions something about viewing linked text while editing a note.  That option controls whether the linked value or the actual syntax is displayed during editing of the note.  I'll check it tomorrow unless someone beats me to it...
I found it.  It's not in Tools->Options.  It's under the View menu.  Make sure that View->Annotation Link Variables is checked.  That will allow you to see the syntax for linking dimension values to a note.
handleman,
Thank you very much!
The syntax was exactly what I was looking for, [example: "RD1@Drawing View2"]. Although, I am very dissapointed to find out that I cannot reference another dimension within a dimension using this syntax. Example: I tried, [<DIM> check out "RD1@Drawing View2"]. The syntax did not reference the dimension. The result was simply, [.250 check out "RD1@Drawing View2"].
Thank you for saving me more hours of trying to figure it out!
