Exploding Simplified Reps.
I have made multiple simplified reps. of an assembly. I am looking for help in exploding just some of the simplified reps and not all for drawing creation.
If possible - please help.
John K.
RE: Exploding Simplified Reps.
I don't believe that you can set an exploded state for a specific rep, however on the drawing for each view you can choose to display in the exploded state or otherwise.  You can also set a rep view by view (as long the view does not have a parent, children inherit the same view settings).
That should be able to get you what you need on the drawing.  Another issue about exploded states is that even thouggh you can view them when setting them, the state is not saved untill you select apply.  If the plus sign is displayed next to the name of the state it is NOT applied.
