Attribute links - radius/diameter
Im using attribute links to reference features of a drawing, but am having a slight problem.
When i try to link to a diameter (pcd) the attribute returned is always a radius.
The pcd dimension is construction geomtry, within a sketch, and dimensioned as a diameter.
Any ideas on how i can change it, so a diameter is given as the linked attribute?
Thanks.
Thanks.
RE: Attribute links - radius/diameter
