Way to store output data at every substep
Is there any way I can store nodal solution data (like displacemnt, temperature, etc..at certain nodes) at every substep into an array or a matrix just like *GET command does for every load step?
I tried OUTRES command but I could only retrieve the results manually (using GUI). There should be some other way when you think of many substeps.
What's the magic command I'm missing here?
Thanks a lot.
Thanks a lot.
RE: Way to store output data at every substep
I think, the most elegant way is to do it in the time processor (post26).
For example you define a node in a variable ND1 and get the results over time with the command NSOL in the variable 2:
/post26
nsol,2,ND1,...
Then you can fill a vector with this results using the command VGET:
*dim,results_nd1,array,number_of_results
vget,results_nd1,2
If you have more nodal results to store the define a matrix instead of vector an repeat the step above.
Alex
vget,
