solving equations simultaneously
I cant seem to get this to work, any suggestions?
a:0
b:0
c:0
Given
76-60-b*3000-a*2000=0  (bouleian =)
80-c*4000-60-b*3000=0  (bouleian =)
c=a+b                  (bouleian =)
Find(a,b,c)=
then i get an error in the find that says the variable or function is not defined above...help
RE: solving equations simultaneously
Not too sure what you mean by Boolean = , I think you have to use the x=y button.
try varying your initial guesses
try using minerr
The error message confuses me, I think the cause may be a typo somewhere rather than the above.
Cheers
Greg Locock
Not sure what you're doing wrong.  It works in v11.
0.0260
-0.0120
0.0140
TTFN
Eng-Tips Policies FAQ731-376
It works in v13 also.
Take a look at your text styles.  Everything should be "variables" except the numbers, 76, 60, etc., which should be "constants".
I've run into the same problem with a different system of equations and I cannot get any results.
I've tried the system as above (mathcad V13) and got same message "Function not defined" or "This variable is undefined".
Any help?
I can e-mail my system of equations to whoever is interested in giving me a hand.
