Looking for Information
Has anyone had any experence with a aeration device operating on a continuous basis and a system bacterial source both installed in an existing septic tank. The claim is that it can recover a failed leaching field. My engineer has not seen this system and has no backround in it. Thanks, Jim
RE: Looking for Information
A septic system has no aeration, otherwise it wouldn't be a septic system.  If you aerate a septic system, solids won't settle due to the mixing.
Also, you don't need a bacterial source.  If conditions for bacteria are present, you will find an abundance of microbes.
Thank you I agree with you but Massachusetts has approved to companies to us this tech in treating failed septic fields just looking for some back round on same, thanks
Please look at this site:
http://norweco.com/html/products/singulair.htm
I work with an engineer that uses these systems extensively in AZ.
Please shoot me a response if there is more I can do to help.
