wood post on floor sheathing
I have a situation in a 2-story existing building where I am installing posts in (4) locations. The posts will start at the first floor and extend to the roof. At the first floor are existing masonry piers with a 7 5/8" wide wood girder bearing on it and I am adding a 5 1/4" LVL to each side. 2x12's stack on top of the girders, and 3/4" sheathing on top of the 2x12's. The 6x6 post is going to bear on the 3/4" sheathing.
I have searched through Simpson's catalog and online but can't find a connector for this condition.
Has anyone else encountered this? How have you handled it? The post is taking gravity load only, no lateral.
In addition to the connection, I am a little concerned about sheathing having to span 2x12's with this post load on it.
Any suggestions would be appreciated, but I don't think I can extend the post through the sheathing to bear on the girders.
RE: wood post on floor sheathing
I didn't understand the role of the 2x12's, and how the sheathing spans them, are you talking about floor joists? Is so solid blocking should be used to ensure a direct load path to the beam.
Is there uplift?
Check the axial capacity of the connector in the simpson catalogue.
DaveAtkins
