Odd Observation in Vibration Response Data
I'm looking for a possible or plausible explanation for the following occurence:
Conducting Mil-Std-167 exploratory sine test on an equipment rack (the UUT is not important to the question). As we progress to each frequency of the lower test range (4-15 Hz) with table displacement of 0.020-inch (double displacement, vertical direction) for each frequency we see an exponentially increasing response on the test points mounted inside the cabinet. So far, so good - no problem.
When we move to the next phase of the test, we are to increase amplitude to 0.060-inch double displacment and progress through the same frequencies and we see at one and only one frequncy (12 Hz) a severe drop off in response in one of the accels. However at frequncies immediately on either side of this 12 Hz we see the expected expontially increasing response (of course somewhat higher responses than at .002 DA input).
We see no other anomolies on the particular accel in any other direction or at any other frequency. It is hard for me to believe that the response measured is actually changing from amplification to attenuation and back to a higher amplification within a band of two Hz.
Can anyone think of an explanation for this ? By the way, we cannot repeat the test or substitue another accel.
Thanks for any thoughts.
Best regards,
Tom
Best regards,
Tom
RE: Odd Observation in Vibration Response Data
Cheers
Greg Locock
I had a typo in my initial question - the anomoly is occuring at 14 Hz, not 12 Hz as stated.
However, it looks like the data is near (but not perfect) multiples of three times as high in the 0.06 test compared with 0.02 tests ONLY up to 13 Hz. Then at 14 Hz, the .002 DA response is .29 g and the .006 DA response is .5 g; then at 15 Hz, the .002 DA response is .35 g and the .006 DA response is 1.75 g.
F .002 Response .006 Response Multiple
9 Hz .096g .28g 2.9
10 Hz .125g .375g 3
11 Hz .160g .470g 2.9
12 Hz .180g .600g 3.3
13 Hz .240g .740g 3.1
14 Hz .290g .500g 1.7
15 Hz .350g 1.75g 5
Some slight non-linearity can be seen at and below 13 Hz. Now I should mention that the equipment rack is mounted on coil type isolators and the test point in question is mounted on a bracket within the rack, so I can see this situation offers lots of opportunity to introduce nonlinearities of all sorts. But my hardship is understanding the large swing in responses within a 2 Hz bandwidth.
I wonder if Tmoose's plot is somehow explaining my observation? Can you help relate it to the data above?
Thankyou all for your interest in this. It's a good problem.
T
Alternatively if those results are in the time sequence they were taken in, maybe that channel crapped out for the last two readings.
Cheers
Greg Locock
