Nozzle for viscous fluid
Any tips or informatin sources for designing a nozzle for viscous fluids.  The requirement is to dispense a thick oil (4,000 cp)with a non-drip shut off.  Flow rate will vary from droplets to volumes of 200 ml/min.  Perhaps the crux is to have the dispensed material exit the nozzle straight without being pulled to one side.
RE: Nozzle for viscous fluid
Google "snuff-back valve". There are many manufacturers.
