wire harness application
I am wondering if anyone who uses the wire harness application can help me.  I need to know if I have a pattern in an assembly, such as a receptacle, and I use the wire harness application to create a wire diagram between the receptacles, will that diagram update automatically if the receptacles change position, and will it increase automatically if the number of receptacles increases?
