good thermal insulator
I am looking for good thermal insulator material that can be machined. Flatness, parallelism, squareness are very important.
The 2 x 1.5 x 0.5 inch block will be subjected to 200 lbs compression force distributed uniformly. The max temperature it can see, is 240°C.
Any recommendations highly appreciated.
RE: good thermal insulator
Check out the physical properties of Marinite and if you need better insulation please post your requirements as thee are others, more expensive, such as rigidized ceramic foams
http://www.bnzmaterials.com/pdf/sumdata.pdf
Your Marinite looks promising. Do you know Macor? I found some info on the Web.
One of our biggest uses for Marinite is a thermal isolator, such as yours, on our polymer processing equipment. It is used on Carver preses in the lab for the same purpose.
