Very thin sheets of metal
4
I'm working on a project where very thin metal plates are needed to obtain the optimal results. The sheets of metal must be as thin as possible.
Does somebody know a company that can deliver extremely thin sheets of metals (stainless steel, aluminium, phosphor bronze, brass). The sheets must be as thin as possible. 30um (micro meter) to 90um. (um = 1e-6m)
Until know I haven't found a company that can deliver those products, because the thickness is too small.
I sincerely hope somebody can help me. Thanks in advance.
Kindest regards,
Vidi
RE: Very thin sheets of metal
How many squre miles of each do you need?
Mike Halloran
Pembroke Pines, FL, USA
Thanks very much for the very valuable posts!
MikeHalloran: +- 1 cubic meter. It's for a project for designing a prototype.
For small quantities in assorted materials,
http://www.mcmaster.com
Just type foil
Al-1100  13, 15, 18, 25,51, 76 & 102 μm
brass (Alloy 260) 25, 51 μm
copper 25, 51, 76 & 102 μm
nickel 25, 51, 76 & 102 μm
stainless (304, 309 & 321) 51 μm
Adhesive-backed is available, too.
And two more, one on each side of the pond.
http://www.alleghenytechnologies.com/ludlum/pages/facilities/newbedford.asp
(formerly known as Teledyne Rodney)
http://www.outokumpu.com/pages/Page____5480.aspx?epslanguage=EN
An I also recall Engineered Metals in MA, I believe that the web is www.cladit.com
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
