Process Engineering Manager
Can anyone describe what are the typical job scopes for a Process Engineering Manager in an injection molding factory?
thanks
deen
RE: Process Engineering Manager
Dear,
Maybe the factory want a guy that knows all parameters include in a molding process (temperature, pressure, injection velocity and the extruder velocity, if have a extruder before injector). You know that this things are very important in a polymer process. So, this worker must be able to decide what parameters he must use for his objective.
Regards!
For the Process Engineering Manager, you should know the processing of injection molding, and how to set-up the parameters for the injection molding machine to achieve the best solution of the parts according to the shape of the parts and the size of injection molds, and assign the production according the time schedule and so on
Molds for Plastic Compression and Injection Molding
