Paste to fill in before powder coat
Is there any paste available which can be used to fill in pits and cavities in iron castings before powder coating which can withstand the baking temperature of around 140deg C?
Nadi
Nadi
RE: Paste to fill in before powder coat
This comes as a B stage (one part, no mixing). Some of the variations will work up to 350-400F.
You will need to cure these before you try to coat.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
http://www.thermobond3.com/
I suggest that you phosphate, rinse & heat off any moisture within pores (& cool) before applying.
