Composite slab properties
I have 9" reinforced concrete slab on 2" metal deck. How can I calculate the composite section properties?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Composite slab properties
or google sdi, they may have a publication.
Dik
A 9" composite slab sounds like you are asking for a ton of shear connectors, you may not be able to get the desired amount of composite action depending on the number of shear connectors you can fit on the beam.
