Arrow's in drawing's
we want our arrows not this <- way but complete black filled up. if we RMB on a dimension en then properties, then we can change it for that dimension, but if we take an other drawing it is wrong ( <- ) again.
is there a way so that this option is default ?
gregory & koen
RE: Arrow's in drawing's
This can be changed in your Drafting Standards file.  Search the forum for mor information.
I've looked in the Standards file and i changed it from ANSI to ISO, but when i reopen Catia it is back to ANSI
If you're opening a drawing you started with the ANSI  standard, then you have to go to file - page setup and update the drawing file standard format to ISO, and hit the update button.
