Notes in family tables window
Is there a way to put notes in the instance window when you open a part that as a family table in it?  All my instances name are the part number of the bolt, washer or nut but when the instance table open, all I can see is the name of the instance and in this case it's a bunch of numbers like 03425. So can I put some kind of note to tell me what size of bolt goes with the part number so I don't need to open 2 or 3 instances before having the size I need?
RE: Notes in family tables window
When you open a family table, ProE gives you the possibility to filter the instances using the fiels you put it in the table.
Look carefully.
-Hora
