Tabled values returning non-tabled results
For some reason whenever I multiply one tabel by another Mathcad 13 is retuning me the sum of all values instaed of another table. I have no pronblem with any other simple operators, why is it doing this?
RE: Tabled values returning non-tabled results
which operator did you use?
Cheers
Greg Locock
multiply, or "*"
basicaly, I have defined a table as a variable D, if i multiply D by itself, or any other table I get a result like the following:
D*D=10.451, where D=1, 3, 4, 2, 6,... (values are made up here but you get the idea)
or D*d=2.345 where D is the same as above but d=3,6,1,4,8 or such
I want a result that reads D*D=1,6,8,4,36... (value 1 gets multipled by itsef, then value 2 etc..
thanks for the help
You need to do it as an indexed operation.
TTFN
Eng-Tips Policies FAQ731-376
Tables are basically the same as matrices.  Your single column tables are vectors which when multiplied (dot product) yield a scalar value.
To get a table that has each element as the multiple of the elements of the original tables, use the vectorize operator, Ctrl+- after getting the editing lines (the little blue angle) under and to the right of both variables.
I guess that is what you want, even though in your example, 3*3 does not equal 6 and 4*4 does not equal 8.
