Help in Sizing and Recommend Components for IC Engine driving a fan
I am fairly ignorant in this area so some expert help would be appreciated.
Application:
25hp internal combustion engine driving a 54" fan.
Engine rpm max is 3600
drive ratio is 2:1
Fan Speed max 1800 rpm
both sheaves will be supported on both sides with pillow blocks on 1" steel shafts.
Engine shaft OD is 1.125"
Would like to use QD bushings if they are adequate
Constantly varying power
Wet environment
Some oil/gas exposure probable
It would be great if you could recommend specific brand/components!
Thanks in advance!
Application:
drive ratio is 2:1
Wet environment
Thanks in advance!
RE: Help in Sizing and Recommend Components for IC Engine driving a fan
Sounds like a neat exam question on the PE.
These guys put at least a 1 7/16 inch shaft in size 27 and up fans, which are rated at 25+ hp at ~ 1800 rpm.
http://www.nyb.com/catalog/bulletins/051.pdf
I guess I am looking for what you would recommend for sheaves and belts in this type of application. I believe that 3V banded belts, and 5VX belts are commonly used. I am interested in keyless bushings since I can eliminate keyways and keys which can vibrate loose and go through the prop causing damage. But I wanted to see what people who work with drive design a lot have to say about the topic.
Thanks!
