Alum Piping
Alum Piping
Alum Piping
Anyone ever used welded Aluminum Tubing?
My customer has told me he doesn't want to use Stainless or Carbon Steel Pipe to connect a Blower to the Dust Filter, he wants to use Aluminum (4 in.).
Anyone have any suggestions/tips on this?
I haven't used Alum OD Tubing so I am a little unsure of any potential problems.
RE: Alum Piping
If you weld it, use the lower annealed allowable stress values.
RE: Alum Piping
I used it years ago for material handling in PVC manufacturing.  It was a dry material (dust like).  It was common for them to use the alum tubing.  Treat it, design wise as you would ss tubing.  I am trying to remember the company name that make the valves, fittings, sweeps, etc.  I will have to look it up and let you know.
RE: Alum Piping
Besides using a high frequency welding machine, not much different.  However not sure what final product is with regards to design/pressure/etc..
