Mastercam X2
Mastercam X2
Hey I'm using Mastercam X2 and Solidworks and I downloaded the add in for direct to solidworks at the mastercam website and I still can't open native solidworks files to show up in mastercam. Do I have to do something in solidworks to get it to work?
RE: Mastercam X2
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
RE: Mastercam X2
Did you select Mastercam Direct in the Tools > Add-ins section? Select both checkboxes if you want it activated in every SW session.
RE: Mastercam X2
Since you are still having trouble, have you called your MasterCAM reseller to have them trouble shoot the issue?
Also head over to www.emastercam.com and check out the forums there.
Anna Wood
SW07 SP2.1, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
WD Raptors, 1 Gb network connection
http://designsmarter.typepad.com/solidmuse
RE: Mastercam X2
RE: Mastercam X2
The whole point of MastercamX Direct is so that native MCAD solids can be imported.
I don't understand why you want/need this but, can MastercamX convert a solid to wireframe after it is imported?
RE: Mastercam X2
RE: Mastercam X2
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
RE: Mastercam X2
RE: Mastercam X2
http://
Chris
AutoCAD 06
RE: Mastercam X2
Heckler
o
_`\(,_
(_)/ (_)
RE: Mastercam X2
RE: Mastercam X2
RE: Mastercam X2
How did you make it work for you?
Chris
AutoCAD 06
RE: Mastercam X2
RE: Mastercam X2
You should be able to import the SW part without the extra step of dwgs and DXF. But, I have not used MasterCAM.
Chris
AutoCAD 06
