Drafting multiple body weldments
I have a large tooling fixture for which I am prepping a drawing package. The fixture is a single catpart with multiple bodies and multiple sublevels of bodies.
We build our models up from individual bodies that are weld prepped, copied or patterned (if necessary), then boolean added to a body which is the weldment, and then machined as a weldment.
My problem is that I need weld callouts on members that are boolean added and thus have no part edges where the welds are. The surfaces of the added bodies are coplanar and the edge disappears from the drawing view. Anyone have a solution for me?
RE: Drafting multiple body weldments
Enter GSD
create a new geometric set.
Select the body
CTRL+F
Workbench = Topology
Type = Edge
Look: = From Current Selection
Search and Select
wait a moment
Extract
Derek
That doesn't work for me. The topology of the surface of the added bodies does not contain a break, so I can not select the top level and have that work for me. Additionally, the wireframe for one weldment is almost 1000 elements. Finally, with the wireframe, my hidden lines show up as solid lines.
I need another method, sorry man.
Good luck!
Thanks for the help all.
