5052 Alloy
5052 Alloy
Good morning,
I notice SW doesn't have 5052 Alloy as the standard out-of-the-box material. The question is why, with all the sheet metal designers and engineers out there?
I need to create and edit a material for 5052 Alloy. I know how to create and edit this, but need someone to help filling in the blanks for values in "Physical Properties"
Value:
Elastic Modulus=
Poissons Ratio=
Shear Modulus=
Thermal Expansion Coeff=
Density=0.097000 lb/in^3 (I have this one)
Thermal Conductivity=
Specific Heat=
Tensile Strength=
Yields Strength=
Thanks for your help,
Value:
Elastic Modulus=
Poissons Ratio=
Shear Modulus=
Specific Heat=
Tensile Strength=
Yields Strength=
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 2.2
Dell 390 XP Pro SP 2
nVida Quadro FX 3450/4000
RE: 5052 Alloy
Matt
CAD Engineer/ECN Analyst
Silicon Valley, CA
http://sw.fcsuper.com/index.php
RE: 5052 Alloy
RE: 5052 Alloy
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
RE: 5052 Alloy
Heckler
Sr. Mechanical Engineer
SWx 2007 SP 2.0 & Pro/E 2001
XP Pro SP2.0 P4 3.6 GHz, 1GB RAM
NVIDIA Quadro FX 1400
o
_`\(,_
(_)/ (_)
(In reference to David Beckham) "He can't kick with his left foot, he can't tackle, he can't head the ball and he doesn't score many goals. Apart from that, he's all right." -- George Best
RE: 5052 Alloy
Colin Fitzpatrick
RE: 5052 Alloy
All the materials had been tested with designs that were approved with major aerospace companies and military. If you see errors, please let me know. Thanks.
Chris
SolidWorks 06 5.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 02-10-07)
