Surface area and volume of eccentric conical frustum
Image a horizontal eccentric conical frustum where one side is flat and parallel with the ground, and the other side sloped changing diameter from 600mm to 1200mm over a length of 1500mm.
does anybody know how to calculation the curved surface area, and volume.
#Thanks
#Thanks
RE: Surface area and volume of eccentric conical frustum
where h = height
A1 and A2 are areas of the bases
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
Lower Alabama SolidWorks Users Group
A = 1/2 (sum of perimeters of base) * (slant height)
These are taken from Burington, R.S. Handbook of Mathematical Tables and Formulas Fifth edition, MacGraw Hill Publishers, (c)1973, Pg. 20
This is simple to understand if you think to how volume and surface would be calculated using calculus.
prex
http://www.xcalcs.com : Online tools for structural design
http://www.megamag.it : Magnetic brakes for fun rides
http://www.levitans.com : Air bearing pads
