Altering board dimensions
I know that you can manually alter the shape of the board using the Design>Board Shape options but this is very tedious and I need precise dimensions.  Is there a way to automatically alter the dimensions of a square board from 108mm x 108mm to 107mm x 107mm?
RE: Altering board dimensions
For times like those, I set the world coordinates to have the (0, 0) point at the board corner and watch the status bar at the bottom... when my cursor hits 107mm, I click.
Dan - Owner
http://www.Hi-TecDesigns.com
I reserve a mechanical layer for the board shape. This is because my boards are not square - they have a very complex shape.
When you have a layer that is the board shape, to redefine you just turn on that layer only, select everything, and use Design > Board Shape > Define From Selected Objects. Quick and easy.
This may not help in your case, but may help someone else.
I do it in a simliar manner but I select the lines and manually enter in the dimensions.
