[b] RENAMING CONFIGURATIONS in Design Table [/b]
Hello Catia users,
We want to rename our configurations.
By default the configurations are named by numbers, starting with 1 up to ...
We want the numbers replaced by names.
Is it possible to change the names of the different configurations?
Greetz,
Koen and Gregory
Greetz,
Koen and Gregory
RE: [b] RENAMING CONFIGURATIONS in Design Table [/b]
Thanks to your fast reply, our problem is solved.
On "Part Design"-Level we added a column to our Design Table and associate it with PartNumber. Then we filled in the column by giving each configuration a partnumber.
Partnumber:
* Small
* Medium
* Large
Those PartNumbers are shown in the tree for the correspondent configuration.
But we also tryed out the catalog, and it seem to be a beter solution if you want to use different configurations in a Assymbly.
Koen and Gregory
