new to COMPRESS
new to COMPRESS
I've been using COMPRESS Build 6251. Due to the low workload and not expecting any project using this software my company decided not to renew our license. For the purpose of internal education in case getting a project later on we review the operation of the software but most of the files I made display an internal error. In this regard, I think there is a need to re-install Build 6251 but cannot find any link in the COMPRESS homepage.
Please help!!!
Please help!!!
RE: new to COMPRESS
Try creating a new file in COMPRESS. Are you able to reopen it without error? If not, then I suggest reinstalling COMPRESS.
Send me 1 or 2 of your files that you cannot open and I will test them at Codeware. Use the address support @ codeware.com.
Tom Barsh
Codeware Technical Support
RE: new to COMPRESS
I re-installed COMPRESS, this time the file would not open because the file was done with Build 6251. We have only in our back-up file of Build 6250.
RE: new to COMPRESS
2) Try the following to correct the "F3" problem:
a) Select Action menu, select Set Mode Options command. Select the "Environment" tab on dialog. "Check" the option to "Disable vessel snapshot", click "OK". Try running calculations again.
b) Or, select the Windows Control Panel. Select the Display icon. Select Advanced Options. Reduce the "hardware acceleration" for the video card.
Tom Barsh
RE: new to COMPRESS
In order for me to run those files, I need a copy of Build 6251. When we updated the COMPRESS software were not able to save a back-up copy of that upgrade.
We are not anymore entitled to receive support for Build 6252, however in one message it says that "Versions of COMPRESS older than November 18, 2006 will continue to function as before."
RE: new to COMPRESS
Tom Barsh
RE: new to COMPRESS
Regards to build 6253:
CODEWARE: [COMPRESS Pressure Vessel & Exchanger Software] with the embed of PAULIN RESEARCH GROUP Nozzle Pro.
ASME BPV Code Section VIII, Division 1 & 2 - Rules for the Construction of Pressure ... the implementation of API-579 – ASME FFS-1 Fitness For Service evaluations (FFS). Link to Mat/PRO and FFS for Level 2 & 3 Fitness for Service Calculations ... Updated Fatigue Reports for latest ASME recommendations and PRG fatigue tests
