Convergence Tolerance
Hi everyone,
I want to ask a question about convergence tolerance. As much as I know, the program determines the convergence when force approaches to the predicted value as close as %0.5 and displacement %5. I also heard something but im not sure yet, which is that, Ansys determines a factor, whose value is different in every simulation, in front of the previous values. When i make a simulation, how can i be sure of the exact value of the convergence tolerance?
My real problem is that, I want to reduce the tolerance of convergence to %0.05 for the displacement values. How can i set it?
One more question, do you have any idea why i cannot solve over 1000 substeps in total when I try to solve 10 loadsteps, which have 200 substeps individually, in a row even though i enter this command when the program is on:
/CONFIG,NRES,10000
Thank you in advance.
Can
/CONFIG,NRES,10000
Can
RE: Convergence Tolerance
Look up the help for cnvtol. It's been a while since I messed around with those settings, so maybe someone else could comment on it further.
I don't know why you'd have any problem with the number of substeps, assuming your nsubst command is entered correctly.
Hope this helps,
Doug
